Re: Couple Questions
Posted by Jon Pando on April 12, 2006 at 12:56:01 from (207.154.79.131):
In Reply to: Re: Couple Questions posted by Nat 2 on April 12, 2006 at 12:46:01:
Yep Ned,
You had me pegged on that one..
I was going too fast most of the time.. Was a bit excited after getting it going after 10 hours of troubleshooting and tinkering.. Won"nt be mowing or plowing nearly as fast as I was driving it..
Not exactly flat out in 3rd gear but faster than I should have been going for what I was doing..
It"s a "68 as it turns out..
And there was a bit of slop in the interstection between the steering arm and the wheel linkage (not sure what that is called)... There is a bit too much of a gap to tighten it down so a bit of shim should get me in business.. The worm gear is still pretty tight..
THanks for the reply..
Jon
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
