Looking for info on an Internatial Tractor
Posted by Pooh Bear on May 18, 2006 at 19:38:02 from (204.116.31.221):
I posted a while back about this.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=531486
I stopped by there today and got some numbers off the tractor.
He told me that since then he has found out the tractor is a D 188
Head Casting Number is 308378R8 (last digit could be a 3).
I found a little aluminum colored plate rivoted onto
the right side of the engine with these numbers on it.
11336 SXY-FF
He needs a head gasket for this tractor.
And he needs the torque specs for the head bolts.
And any other info he can get about this tractor.
Thanks.
Pooh Bear
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
