Re: Looking for info on an Internatial Tractor
Posted by TDK on May 18, 2006 at 20:49:27 from (152.163.100.65):
In Reply to: Looking for info on an Internatial Tractor posted by Pooh Bear on May 18, 2006 at 19:38:02:
The D-188 diesel engine was only offered in the International & Farmall 504 and the 2504 Industrial tractor if I'm not mistaken. They were built between '62 and '68, 46 pto horsepower. According to the serial number you listed it's a '65 model. The letter suffixes mean - S = Torque Amplifier w/provision for Independent PTO, X = High Speed Low & Reverse Gears, Y = 12 G.P.M. Hyd. pump, FF = 4.5 G.P.M. Hyd. Pump. The head gasket number is 308379R3 and the torque for the head bolts are 75 - 80 ft. lbs.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
