Re: Distillate manifold
Posted by Mister H on June 15, 2006 at 05:24:43 from (12.155.240.196):
In Reply to: Re: Distillate manifold posted by Tom Windsor on June 15, 2006 at 05:06:24:
By "welded up the holes" do you mean that you closed off the heat jacket or were there some holes in the outside of the manifold that you repaired?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
