Re: IH 584 Starter Grinding
Posted by ABB on June 18, 2006 at 15:01:43 from (70.244.171.138):
In Reply to: Re: IH 584 Starter Grinding posted by RustyFarmall on June 18, 2006 at 09:53:29:
Good thoughts and thanks for the time and effort. I didn"t see any shim or gasket or spacer between the starter and the engine case, but didn"t check bendix. I guess I"ll pull starter off and take a look for myself. Three bolts and it is off, I think. Anything else to look for while doing it?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
