H ignition problems
Posted by DCW on July 01, 2006 at 17:08:18 from (156.34.159.164):
I have a 41 H THAT I've recently finished restoring.The tractor has been converted to 12V,THE ORIGINAL MAG IS GONE,AND IT HAS A M&W LIVE HYDRAULIC PUMP ON IT AND AN IH DISTRIBUTOR ON IT.The tractor sees no work,and is a hobby tractor,and is kept inside out of the weather.
The problem I'm having is occasional hard starting,rough running,and bad condensation build-up inside the dist,to the point that I can blow the water out with compressed air.I have a 12v coil on it now,and I added a ballast resistor to the circuit between the ignition switch and the coil.The condensation fouls the points.Sometimes it will only run on 2 cylinders,then smooth up and run fine.The coil is old,but it doesn't appear to be getting hot.A look inside the dist now and you'll find a rusty film build-up on everything.I tried leaving the dust plate out of it,that doesnt appear to help.
The points don't appear burned,but the water inside rusts them
I'm on the verge of changing it to electronic ignition.
Any one encounter similar problems-I did a C last year and had no ignition problems,and they shared basically the same ignition parts.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
