Re: H ignition problems
Posted by John T on July 01, 2006 at 18:49:15 from (66.244.90.5):
In Reply to: H ignition problems posted by DCW on July 01, 2006 at 17:08:18:
DCW, For one thing if its a 12 volt system YOU SHOULDNT USE AN EXTERNAL BALLAST RESISTOR if its really a true full 12 volt rated coil UNLESS its a coil thats labeled "12 volts for use with an external Ballast Resistor" No wonder the coil never gets hot !!! cuz if its really a 12 volt coil and you added an external ballast resistor youre only running something like 1/2 the current through it thats its designed to handle PLUS that causes a weak spark and poor running.
Check the coil and if its really a true full 12 volt (internallay ballasted) coil then THROW OUT THE BALLAST and you should get a hotter spark and better performance. Of course, if its a 6 volt coil then you need the ballast.
John T
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
