Re: my H went nuts
Posted by old on July 19, 2006 at 14:46:19 from (4.245.6.240):
In Reply to: my H went nuts posted by meathead on July 19, 2006 at 14:07:06:
Use what ever oil you use in the engine for the oil cup in the aircleaner. As far as you running problem check the sediment bowl clean it out. Also after doing that pull to drain plug from the bottom of the carb and make sure you have a good glow of gas, you may get some water out of the carb when you do and if you do you probably found part it not the whole problem
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
