Re: STARTER BUTTON
Posted by glennster on August 09, 2006 at 14:20:58 from (68.79.56.106):
In Reply to: STARTER BUTTON posted by Larry Chapnick on August 09, 2006 at 11:37:24:
my 1942 m has the starter button at the base of the steering post below the light switch box, it is a straight rod with a mushroomed head. my 48 and 51 m both have the starter in the same location but it is a bent rod. the 42 is kind of a pain because you have to twist yer toe a little to push the rod in.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
