Re: 88 series 2+2
Posted by ETNFARMBOY on October 08, 2006 at 20:16:54 from (66.191.226.33):
In Reply to: 88 series 2+2 posted by James Peterson on October 08, 2006 at 18:34:24:
I agree that there has to be an underlying problem somewhere. Either in the fuel getting to the pump, either contaminated or something restricting the flow. If the fuel flow is too low it may cause problems because most fuel pumps are cooled and lubricated by the diesel going through the pump on its way to the injectors. Or it the type of pump your obtaining but more than one remaned or rebuilt pump going is odd. We have a "84 5288 that has the original pump and so far (knock on wood) have had no problems. Not sure if that helps but it really may be a fuel flow problem.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
