Re: Duals again
Posted by billde on November 26, 2006 at 08:01:38 from (66.249.39.139):
In Reply to: Re: Duals again posted by Wardner on November 26, 2006 at 07:27:36:
I believe they were 24.5x30 they were oddball rice tires. My point was that with duals it was not manuverable, the brakes just wouldn't hold to make power turns. The brakes are good enough to stop you or hold on an incline, but you will burn them out trying to turn in the field.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
