Re: Plug wires
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill B on February 06, 2000 at 06:05:58 from (209.182.66.111):
In Reply to: Plug wires posted by Jeff W on February 05, 2000 at 16:06:49:
I would use the copper or the steel core, but not the carbon resistor wires. The silicone insulation may be nice, but the solid wire will deliver the voltage better, and for a longer period of time. The resistor wires only last so long, the solid wires last almost forever, and it will be the insulation that will go first. Unless you have an am radio on your tractor, you dont need resistor wires, or resistor plugs. Those stiff black wires are correct, and look great.
Post A Followup
: Re: Re: Plug wires
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
