Re: H rear end update HELP!!!
Posted by Nat 2 on June 26, 2007 at 13:02:00 from (64.80.108.53):
In Reply to: H rear end update HELP!!! posted by Bob Kerr on June 26, 2007 at 12:41:07:
The noise is probably caused by the mismatched wear patterns between the one gear you replaced, and the one you didn't.
Gears really need to be replaced in pairs.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
