Re: Looking for Ealry Farmall B Radiator
Posted by gene bender on July 03, 2007 at 04:04:49 from (67.55.226.214):
In Reply to: Looking for Ealry Farmall B Radiator posted by Michael Karg on July 03, 2007 at 03:51:26:
By early you must mean the one that uses the DUEZ fasteners for the sheet metal as the two radiators are not interchangeable an you will not find a new replacement with the fasteners so you will need a good used one.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
