Re: Farmall B alternator/ammeter
Posted by ScottyHOMEy on July 31, 2007 at 19:53:33 from (70.105.246.111):
In Reply to: Farmall B alternator/ammeter posted by Dave H (MI) on July 31, 2007 at 19:21:54:
If the ammeter is working and hooked up properly it should show a discharge with the engine off and the lights on. It should also drag down when you hit the starter, ignition on or off.
Put a charger on your battery overnight and see if it runs okay for a while the next time you run it. That'd be a tip. And, if you get a few minutes in between those extended returns you're workin' on, give a look at Bob's diagrams for the 12v setups. Strikin' me more and more as a good place to start.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
