Re: Farmall B alternator/ammeter
Posted by El Toro on August 01, 2007 at 06:22:31 from (205.188.117.137):
In Reply to: Farmall B alternator/ammeter posted by Dave H (MI) on July 31, 2007 at 19:21:54:
Take a volt meter set on DC voltage and measure the charging voltage at your battery with the engine at about 3/4 throttle. Should read around 14 to 14.5 volts. Hal
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
