Look at That Static Discharge!
Posted by A. Bohemian on August 01, 2007 at 07:54:00 from (207.170.88.12):
In Reply to: Re: Farmall B alternator/ammeter posted by teddy52food on July 31, 2007 at 20:09:57:
All you have to do to test the ammeter is turn on the ignition. We usually think of static discharge as an expenditure of electrostatic energy stored in our bodies and clothing, usually between a doorknob and the nerve endings of our fingers (''Ouch! Darn!''). Static discharge can ALSO refer to the normal discharge which occurs in a Kettering ignition system with the ignition on and the engine at rest (or STATIC). A discharge occurs because the points are closed, completeing the path to ground through them. Most original 6-volt Kettering systems on Farmalls show a static discharge of about 4 amps. If you have an alternator you probably have a non-standard ignition system (12 volt conversion), but UNLESS an electronic ignition has ALSO been installed, you should see a static dishcharge of some kind in the range of 2-4 amps. So, turn on the ignition. If the meter does not deflect to show a slight discharge it is stuck, or (more likely in a 12-volt conversion of unkown quality) disconnected because the person doing the conversion didn't know how to make it read properly after the polarity switch (simple). If the tractor does have points, it would NOT be running if the static discharge were NOT present. So a properly connected and functioning ammeter MUST show it. If the meter has NOT been connected properly, and you didn't do the conversion yourself, be suspicious of the whole conversion job, as most people who understand these systems know how useful an ammeter is and will make sure it is in circuit and functioning properly before they deliver the job to a customer. Read the procedures and tips for conversions on these boards and elsewhere and take a good look at yours. Remember, if the ammeter is disconnected, you've already found ONE thing you need to fix...
Home
| Forums
Today's Featured Article -
The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
