Posted by gene bender on August 18, 2007 at 10:29:45 from (67.55.226.214):
In Reply to: polarize posted by noidea on August 17, 2007 at 21:17:53:
You didnt say which tractor and what ground you have. None of the other responses asked either. You should have pos ground then just touch the batt term to the arm terminal on the gen with a piece of wire. It will spark and you are done then the ammeter should show charge when you start the engine. Im guessing that is why you say it is charging backwards as the ammeter is wired for pos ground. I you ever change the cut-out to a reg make sure you get a reg for the ground you are running as most new regulators will say pos gnd for the older stuff.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
