Re: Spark plug gap
Posted by glennster on November 12, 2007 at 06:03:19 from (76.224.26.7):
In Reply to: Spark plug gap posted by Mike CA on November 12, 2007 at 00:05:03:
mike, i set mine at .025. the autolite plugs you have are non resistor plugs. they work well in your tractor. the 386 is the resistor version of the plug you have.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
