Re: Schrader spark plug tire pump kit - worth it? available?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Burrhead on February 22, 2000 at 09:17:39 from (12.74.17.88):
In Reply to: Schrader spark plug tire pump kit - worth it? available? posted by Jim on February 21, 2000 at 16:21:34:
It was a good idea. They still work good today.
Some times people forget that when this type tools were equipment on tractors and pickups that there were several areas that did not have electricity, or tire service companies or farm centers or service trucks. If there had been mobile services available most folks would have still repaired their own tires anyway.
For tractor or pick up truck tires they were wonderful, they beat the heck out of a hand bicycle tire type pump. Them old pumps and "Monkey Grip" brand self vulcanizing patches were used alot.
John Deere also had a small air compresser that you slipped onto the pto and pumped up a tire. Just about the size of a medium coffee can.
I had an air compresser by Lincoln that had a Continental 4 cylinder engine, it ran on 2 cylinders and 2 cylinders had the same schrader valves in it that you're talking about here.
It would build enough air to run jack hammers and 1" impact wrenches very good.
Post A Followup
: Re: Re: Schrader spark plug tire pump kit - worth it? available?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
