Check the steering column. If you have the worm gear bearing seated well, the steering column may be loose or bent. This is the structure that holds the steering wheel. It should have two set screw rings around the steering shaft to hold it in place.
Also, if you have the tractor jacked up and have loosened the frame rails, you may be out of alignment there, that is, if the frame rails are loose and hanging down toward the front, the steering shaft will be too short. Same thing if the bolster has been loosened.
Did you make sure the seat for the worm gear bearing was clean?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
