positive or negative ground?
Posted by H project on December 10, 2007 at 17:03:36 from (65.254.162.234):
I just bought my first farmall to restore a 44 H. The owner had did away with the magneto and put a distributor on it. My question is all the wiring diagrams show a positive ground but he had it set up as a negative ground. Can anyone lead me in the right direction. It is a 6 volt system and I am having a lot of trouble getting enough juice to get it cranked. Runs fine after you crank it. I have replaced the battery,points,plugs,distributer cap and plug wires. First restoration project so any help is greatly appreciated, Thanks.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
