Re: positive or negative ground?
Posted by RAW in IA on December 10, 2007 at 17:20:55 from (12.215.87.124):
In Reply to: Re: positive or negative ground? posted by farmhand on December 10, 2007 at 17:16:55:
If I remember right, the Generator can be either but the regulator is made for either posor neg ground and cannot be used on the other.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
