Re: positive or negative ground?
Posted by old on December 10, 2007 at 18:11:39 from (4.245.6.207):
In Reply to: positive or negative ground? posted by H project on December 10, 2007 at 17:03:36:
When new it would have been + ground. If all is as it should be an H will start just fine on 6 volts but all has to be as it should be. You need the right size battery cables as in 0 or 00, the tractor has to be tuned up good and the starter needs to be in good shape. Any one or all of them not right means a hard to start tractor on 6 volts
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
