Re: positive or negative ground?
Posted by BillyinStoughton on December 11, 2007 at 07:02:21 from (69.214.162.13):
In Reply to: positive or negative ground? posted by H project on December 10, 2007 at 17:03:36:
The boys got some good ideas for you here. 6 volt positive ground is how your H started it's life. As stated below, the most important things to making a reliable 6 volt system is:
0 or 00 gauge cables (I buy my cable at a welding supply house and then solder my connections and use industrial shrink wrap to seal the joint).
Good clean connections at every point (generator, starter, battery, ammeter, etc).
A good battery.
A charging system that matches the battery set-up in the tractor.
A clean fuel system and properly adjusted carb help out a h*lluva lot when it comes to starting too!
I have two Farmall's (H and M) that are still 6 volt positive ground and they start marvelously in this beautiful Wisconsin weather (the H popped off yesterday morning at a whopping 6 degrees)!
That should give you some places to start. Good luck with it. Let us know if you need anything else!
Billy
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
