Re: power steering for a C
Posted by georgeky on January 09, 2008 at 10:49:12 from (205.188.116.73):
In Reply to: power steering for a C posted by Vicki Westerhoff on January 08, 2008 at 16:55:05:
If you go to the larger wheel it will help a bunch, will also need the bracket from a SC or 200 that the steering shaft rides in attached at the side of hydraulic controls. It will change the pitch of the shaft and give more knee clearence for the operator. One from the 230 will fit and work, but doesn't look original to the C or SC/200.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
