Re: Negative Ground Part III - another question
Posted by Janicholson on January 25, 2008 at 06:19:08 from (199.17.6.122):
In Reply to: Re: Negative Ground Part III - another question posted by Janicholson on January 25, 2008 at 06:11:22:
As an added element of reduced "suprise" I also recommend testing your meter by checking the tractor with a good analog (needle and scale type) meter. If yours is digital, the method of interpreting noisy systems (yours is noisy) may cause less than reliable indication. Best of luck, JimN
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
