Re: Farmall 300 carb problems
Posted by 3dhuth on February 09, 2008 at 08:37:06 from (68.27.238.37):
In Reply to: Farmall 300 carb problems posted by Rick in Idaho on February 09, 2008 at 08:24:20:
When you say choke wide open ,do you mean you are chocking the carb. If so then it is likely you have a plugged main jet passage in the carb.By closing choke plate you are causing engine to pull more from the fuel side of carb and less air flow. When you open choke engine dies because it is too lean.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
