Re: First attempt at start. It's not catching
Posted by Andy Motteberg on April 02, 2008 at 18:28:25 from (4.143.217.248):
In Reply to: First attempt at start. It's not catching posted by Mike CA on April 02, 2008 at 18:21:00:
Back when my H had a key switch on it, I had it wired wrong and it would run with the starter turning, but not when you let off the switch. Something you could check if you have a starter button style switch is make sure the wire that goes into the amp box to the starter button switch is on the side that goes to the battery, NOT the starter.
Good luck!
Andy.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
