Posted by teddy52food on June 23, 2008 at 01:16:53 from (209.237.111.169):
In Reply to: 656 poblem posted by DaveIN on June 22, 2008 at 19:49:51:
Use a piece of gas line hose with a piece of tubing on one end. Siphon the gas out moving the tubing around the bottom of the tank next to the drain (outlet). Siphon the gas in a clear jug or white pail and watch for the junk coming out. This may save pulling the tank or sediment bulb assembly.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
