I would check for fire to the sparkplugs by pulling off one of the plug wires or the coil wire and hold it near a good ground. You will need the ignition switch on too while cranking. Does that LP tank have a gauge? Your tank may be empty if there's good fire to the plugs. Hal PS: You will need a helper too.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
