Disc Brakes for Super M
Posted by CHIEFEAVES on August 07, 2008 at 02:59:11 from (64.12.116.73):
My neighbor just replace the disc brakes on his super M and there is a problem. When you apply the brake pedal it does not stop the tractor. If you put real heavy preasure it will slow the tractor down only. Any suggestions are appreciated.
Harley
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
