Re: Still having problems with my Cub Light
Posted by rusty wheel on August 16, 2008 at 19:44:07 from (76.181.63.141):
In Reply to: Still having problems with my Cub Light posted by Retcol on August 16, 2008 at 14:21:42:
Be cardful bending that strip of brass, it breaks very easy. Sounds to me as if you have a bad socket, or the wire comming out of the back of the socket might be broken inside the insulation
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
