Re: Starter Bendix Sticking
Posted by Owen Aaland on August 20, 2008 at 17:47:23 from (65.161.86.52):
In Reply to: Starter Bendix Sticking posted by Formerly PaMike on August 20, 2008 at 17:31:04:
Formerly PaMike said: (quoted from post at 17:31:04 08/20/08) I just got the starter for our 350 Utility rebuild and it was working great, but now the bendix sticks, and wont spin out. I pulled the starter and the bendix was sandblasted and cleaned up when they rebuild the starter. The bendix will spin out fine by hand, but it you spin it back as hard as you can it "sticks" then you cant spin it back out. Anyone have any ideas?
If the drive was sandblasted, make sure there is no blast media remaining in the splines that can cause problems. Also be sure that it is lubricated with oil and not grease. Grease can cause problems in cold weather if it gets too stiff.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
