Re: Front end Swap
Posted by RustyFarmall on November 25, 2008 at 12:18:32 from (209.152.78.9):
In Reply to: Front end Swap posted by Lance_MF_180 on November 25, 2008 at 10:53:36:
Some folks claim to have done it, but if you have a narrow front from an H, and a narrow front from an M, place them side by side and measure the distance between the mounting bolt holes, you will find there is a big difference. Also, most Ms have much larger spindles hubs, and wheel bearings than what is on an H. Wide front axles can sometimes be swapped also, but considering that the M is a full two inches wider than an H, it will not be a direct swap.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
