Re: QUESTION ABOUT A 1959 140 FARMALL.
Posted by BDC on December 06, 2008 at 07:20:56 from (166.217.60.125):
In Reply to: QUESTION ABOUT A 1959 140 FARMALL. posted by Rob Myhren on December 05, 2008 at 17:00:48:
Hugh MacKay said: (quoted from post at 03:33:01 12/06/08) BDC: The grill with horizontal bars was used from 1958 until mid 1963. It was the styling of the era and that same styling was used on 240, 340, 460 and 560.
The grill changed to the small holes in 1963 being the same styling as 404, 504, 606, 706 and 806. Why IH didn't change the model number on the 140 is a qood question. I guess a good answer would be 140 did not change mechanically, however there were significant changes in the larger mo
dels.
THANK YOU MINE HAS A PLANE SMAILL HOLED PIECE OF METAL THAT STICKS OUT ABOUT 3/4 IN AND IN 3/4 OF A IN OUT AND IN. MY SERIAL NUMBER IS 37 OR 37 50 J I'M MISSING THE IH BADGE. ALSO DO YOU KNOW THE HEAD TORQUE AND ROD CAP TORQUE THANK YOU SO MUCH .BDC
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
