Re: Jump starting an 8-volt system with a 12- volt system
Posted by old on December 27, 2008 at 21:09:53 from (4.245.7.206):
In Reply to: Re: Jump starting an 8-volt system with a 12- volt system posted by bthansen on December 27, 2008 at 20:19:40:
Guess you don't know much about zap-u-trons then. Very very hard to get hurt by 12 volts or 6 volts or 8 volts unless you do things when you hot and sweaty. Plus if your holding on the the plastic that is on jump cables there is not way to get shocked. Under normal condition the average human has to has at least 32 volts to be shocked. I.E. normal humans have a resistance high enough to keep from being shocked with less then 32 volts but go over 32 volts and yes you get shocked. But if you want to think that way I can kill you with a D cell flash light battery if done right
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
