Re: Re: H overhaul
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Wardner on April 05, 2000 at 09:21:00 from (63.23.215.128):
In Reply to: Re: H overhaul posted by super M on April 05, 2000 at 06:25:00:
This whole thread is ambiguous because you won't tell us what you have for a motor. If it is a '52 and looks something like an H, it is actually a Super H and you are all set with the 3-5/8 kits. You can also get big bore kits for the H as well, but they will only be 3-7/16. If you can't find C-169 cast into the right side of the block near the fourth cylinder, you have a H motor. Either way all you need are the right kits and standard gaskets. Nearly everyone who rebuilds their motor goes for the big bore thin sleeve kits. Forget about boring your block unless it is damaged.
Post A Followup
: Re: Re: Re: H overhaul
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
