Re: External Regulator... or not
Posted by karl f on February 03, 2009 at 10:55:08 from (209.188.106.159):
In Reply to: External Regulator... or not posted by Saw Dust on February 03, 2009 at 10:11:31:
If the electrical system is pretty much in good condition, i would leave it as is and repair or replace the regulator--especially if it is delco. A starter and alternator repair shop should be able to help you out. if you are in an area more urban or the stores are all retail oriented, a delco regulator from a 1969 chevy pickup with a 292 would likely be the same as the IH. If it is not delco, let us know and we'll see what other ways we can help you.
karl f
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
