Re: Farmall B Timing
Posted by Bob on February 23, 2009 at 09:32:32 from (69.178.228.68):
In Reply to: Farmall B Timing posted by Eric Skokan on February 23, 2009 at 08:31:42:
1.) The rotor gear and the little gear next to the cam that drives it are MARKED.
To see how that works, paste the link below into your browser and go to Pages 51 and 552.
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-5035%20Service%20Manual%20Magnetos/index.html
2. The timing marks on the flywheel and the casting ahead of it (at the bottom) should just be in register at the moment the mag's impulse snaps.
Setting the mag timing EARLIER than this will cause "kickback", which will break the starter, either YOU or the electric version.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
