Re: McCormick-Deering 10-20 done! (2527)still can't crank...
Posted by James Williams on May 28, 2009 at 13:34:18 from (170.215.131.125):
In Reply to: McCormick-Deering 10-20 done! (2527)still can't crank start posted by dave.koenigsfeld on May 28, 2009 at 07:55:27:
Dave,your timing is probally off some,My F 12s does the same thing.Play around with your mag advance and see if it will try to start a little better in different positions.Do you have the timing mark marked,and is the coupling snaping when the mark is in the center of the sight hole
jimmy 304-582-9995
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
