IH 656 Farmall PTO only works part of the time
Posted by JJ in Iowa on July 02, 2009 at 18:12:43 from (70.215.54.86):
Can anyone help me? I was mowing hay with my IH 656 and broke off the PTO engaging lever. If you try to operate it by lifting on the "linkage" jsut above the PTO it will engage as long as there is no load on it. Once you hook a mower or bailer to it, it will run for a second and then stop eventhought the PTO is engaged. Does anyone have any ideas? I have noticed that the rubber boot going into the PTO linkage is split, could it be leaking pressure there causing the PTO to stop running?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
