Re: Question about Sand Blasting
Posted by dhermesc on August 21, 2009 at 06:54:41 from (24.248.193.103):
In Reply to: Question about Sand Blasting posted by Sam Eubanks on August 21, 2009 at 05:50:03:
If you want 100% restoration you need to keep shopping. However, if you are paying someone to do all the work you should realize you'll have at least double what the tractor will ever sell for - if not more.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
