Re: Question about Sand Blasting
Posted by Sam Eubanks on August 21, 2009 at 08:00:50 from (148.168.40.4):
In Reply to: Re: Question about Sand Blasting posted by ScottyHOMEy on August 21, 2009 at 07:09:23:
The tractor is a 1952 Super AV.
I want someone to use the same process that you mentioned.
My problem is the guy doing the restoration is EXTREMELY knowledgable about Farmall parts, etc. My only concern is his process of blasting the entire tractor and then painting without disassembly.
In other words, he blasts and paints after the tractor has been mechanically repaired.
Thanks for all the great feedback.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
