Re: Question about Sand Blasting
Posted by Andy in Manteca on August 21, 2009 at 15:25:54 from (71.6.120.26):
In Reply to: Question about Sand Blasting posted by Sam Eubanks on August 21, 2009 at 05:50:03:
I have sand blasted a few tractors, one we did last weekend. The sand will get into everything. Its amazing how it works its way in tight spots. You must at least remove the head and oil pan and rear reduction gear oil pans and clean, clean, clean. I try to stay away from sand blasting the whole tractor. Some of the advice on this thread is very good.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
