Re: Question about Sand Blasting
Posted by mattofvinings on August 21, 2009 at 16:37:30 from (67.142.161.29):
In Reply to: Question about Sand Blasting posted by Sam Eubanks on August 21, 2009 at 05:50:03:
My thoughts are sandblasting is never appropriate for an "assembly" that isn't going to be completely disassembled, degreased/cleaned, blown out with high pressure compressed air and then reassembled.
So..along those lines, it's great for body panels, hoods, etc, and parts like the drawbar or a frame-rail.
Anything that moves, spins, etc, will get the grit in it...unless they're blasting with walnut shells...a bad move IMHO. The grit has an amazing affinity for the least bit of grease or oil. It also has an affinity for rough-cast surfaces...only a powerful air blast can get it out again.
This post was edited by mattofvinings at 16:39:00 08/21/09.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
