Re: piston ring installation
Posted by Janicholson on August 24, 2009 at 17:45:26 from (64.61.211.234):
In Reply to: piston ring installation posted by SDE on August 24, 2009 at 17:24:11:
Spaced at 120 degrees is fine orientation to the block is not important. Your expander on the oil ring should have its butted ends at least a third of a circle away from the scraper rail gaps. again no orientation is needed. Clean the bottom of the grooves well before putting them on, or it will lock up and seize. Checking end gap is also extremely important (push a ring into the bottom one inch of the cylinder so it is level and square. Measure the gap with a series of feeler gauges to assess the gap. If it is too tight the engine will seize. Oil the rings with engine oil and use a good sleeve type compressor to get it in the bore. Do not "nick" the crank journal with the rod big end. JimN
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
