Posted by Andrew Z on January 19, 2010 at 17:00:48 from (64.252.113.90):
In Reply to: IH Model H posted by gmonnens on January 19, 2010 at 16:44:33:
The trans and the hydro pump are diffrent units. The rearend use 80w-90 gear oil. for the hydro pump use 30Non detergent oil. The fill plug for the rear end is the large plug that is near the steering post support. The hydro pump is filled on the right side while sitting on the tractor. The cap should be a cast mushroom shape, add 6 quarts to there again 30 ND oil. Enigne oil you can use what ever you want i use either 30 ND or 15w-40 oil. That takes 6 quarts as well. The cooling capacity is 4 1/4 gallons.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
