Re: H died and I can't figure out what's wrong
Posted by pete 23 on March 31, 2010 at 18:57:24 from (173.87.145.42):
In Reply to: H died and I can't figure out what's wrong posted by Zachary Hoyt on March 31, 2010 at 16:36:57:
Slot headed shaft at lower front of carb, hummmm. Sounds like the metering nozzle nut and if the nozzle is cracked it will not run well as they are your air bleeds that change the mixture as the venturi vacuum changes when coming under varying load. Maybe I am not understanding what you are putting down though.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
