bench testing a voltage regulator
Posted by glennster on April 18, 2010 at 18:40:28 from (99.90.9.153):
any way to bench test or adjust a 6v pos ground v-regulator? bought a brand new one last year from case-ih and had it on the shelf. went to put it on my m, nada-zip-zilch. its a made in the usa, went thru john t's secret test proceedure, and the v-reg is the problem. genny will put out close to 25 amps with the field grounded. here is the varmint. maybe i should throw it around the shed a couple times and see if that helps. contacts are all clean and shiny
third party image
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
